2,3 DOHC 16v scorpio
Taunusmk3
Viesti Kirjoittaja Taunusmk3 »
Hello would like to install an engine from a Scorpio 2.3 liter dohc in a Ford Taunus how can I best bypass it with the electronics and the immobilizer
Re: 2,3 DOHC 16v scorpio
You will need a complete wiring harness for the motor and ignition key. Without them, you will have to build a wiring harness aftermarket around the ECU.
