2.4 v6 ruiskun sähköt
Lähetetty: 01 Heinä 2012, 17:32
Kirjoittaja henkka
eli tietoo mitä johtoja nuo 9 on jotka tulee boksilta? kone ja ruiskut vissiin -87 kahella ilmamassamittarilla ilman lambdoja.
uudemmat kytkentäkaaviot oon löytäny mut en tätä vanhenpaa jossa ilmamassamittarit
siis se liitin johon kytketää 12v ja josta saa kiekkamittarin jne...
Lähetetty: 01 Heinä 2012, 23:22
Kirjoittaja henkka
pitää huomenna käydä kattoo hallilla onko täst mitää apua..
tossa jotain: Well you have put it off but its time now to wire the ecu. If you’re using a Mk2 2.8i your life is easy.
If you are starting with a more basic model you have a little more work to do.
On the loom you removed from the donor car you have a plug, which is where the ecu loom wired into the cars main loom.
From this point you have to connect four cables.
1. BLACK / GREEN wire (STARTER MOTOR) this wire is spliced into the ignition switch or you can locate the wire in the passengers’ side foot well.
(The colour of the wire to look for on the Mk2 is Black / Blue).
2. GREEN wire, (TACHO PULSED SIGNAL) this goes to pin 1 where the purple relay used to live on the 2.8i or wire it to the green wire at the back of the tachometer (rev counter).
3. BROWN wires, (EARTH) these go to the body of the car - located in the passengers’ side foot well.
4. BLACK / RED wire (FUEL PUMP RELAY) this goes to pin 87 where the purple relay used to live on the 2.8i or wire it to the fuel pump.
A note here, the Mk3 uses a shunt fuel cut off switch which you will find in the boot of the car you have just broke.
Taking the time to wire this switch in series with the fuel pump supply is a good idea on a safety point but totally optional.
5. BLACK wire (SWITCHED IGNITION LIVE) this goes to pin 15 where the purple relay used to be on the 2.8i or again straight to the ignition switch on non-injection models.
6. RED wire (BATTERY LIVE) to the battery + terminal.
7. If you are working on a 2.8i you need to extend the cable from the temperature sensor (which you may also need to change over from your old engine) to the cable you previously cut off at the bulkhead.
The cable colour is WHITE / PINK. Non-injected engines will have the temp sensor lead long enough to reach the sensor on the 2.9 engine.
While you’re in the foot well, pull out the green relay if your working on a 2.8i as its no longer needed.
Fix up and tidy the cables under the dashboard making sure you have access to things like the relays and fuse. Its best if you solder the wires into the loom as there is less chance of problems later with bad connections.
Lähetetty: 02 Heinä 2012, 05:50
Kirjoittaja Luhtis
Muistaakseni kolme karvaa tartti kytkeä, niin se lähti jo käyntiin. Mulla on ihan paperimuotoset kaaviotkin, ku ny vaan muistas missä.. Tallilla pitäs olla myös muistiinpanot kun itse tein kyseisen homman parivuotta sitten, pariin autoon.
Lähetetty: 02 Heinä 2012, 15:24
Kirjoittaja Samu
mulla on 2.8 efin orkkis johtosarja ja siitä jäi jonkun verran johtoja liittämättä koska tanessa ei oo mitään pakokaasun kierrätyksiä yms turhaa... mitä nyt äkkiseltään muistaa niin puolalle meni ainakin pari johtoa, ilmamassamittareihin oli molempiin liittimet, tyhjäkäynnin anturi ja siinä vieressä pari muuta anturia/liitintä, jakaja ja sitten vielä pari relettä ja sulaketta ja bensapumppu noiden releiden ja sulakkeiden läpi.
piratebaysta ainakin löytyy haynesin opas scorpioon missä selitetään v6, ohc ja dohc ja siinä on sähkökaaviot ja kaikki
Lähetetty: 02 Heinä 2012, 21:28
Kirjoittaja henkka
miulla on scorpin johtosarja, tuo liitin on siin sarjassa lähellä ruiskuboksia, liittimen kautta menee sit auton johtosarjaan, kytkin nyt näin saa nähä toimiiko..
1. BLACK / GREEN wire (STARTER MOTOR) : virtalukon startti asento
2. GREEN wire, (TACHO PULSED SIGNAL) kiekkamittari
4. BLACK / RED wire (FUEL PUMP RELAY) bensapumput
5. BLACK wire (SWITCHED IGNITION LIVE) virtalukon 2 asento
loput 5 siitä liittimestä on varmaan joutavia, (mittaristolle ö-paine, veden lämpö jne..) kun käyttää niitä varten tanen omaa johtosarjaa..
3. BROWN wires, (EARTH) nämä eivät olleet liittimessä vaan 2 "irrallista" johtoo siitä vähän matkan päästä, kengät päissä joten runkoon kiinni
lisäks konehuoneen puolelta plus ja miinus ovat siin johtosarjassa
kuhan saan startti kuntoon nii kerron toimiiko
Lähetetty: 02 Heinä 2012, 21:31
Kirjoittaja henkka
ja tämä siis 2.4 efi -87 2 maf anturilla ilman lambdoja
että löytyy sit guuglella
Lähetetty: 02 Heinä 2012, 22:16
Kirjoittaja Luhtis
Juurikin noin oli mun muistiinpanoissa kans. Tärkeintä tossa ehkä että se virtalukon starttiasennolle kuuluva johto kans on siinä starttaus-asennossa. Sen karvan tarkoitus on että kun siinä on jännite, ecu hoksaa että nyt koitetaan saada kone käyntiin, ja pitää sytkäennakon muistaakseni kiinteässä 10 asteessa. Jos siinä siis on jännite kun kone käy, niin ennakonsäätö ei toimi. Tolla ennakolla kun lähtee lasettaa koeajolenkille niin varmasti on vedot kateissa (ja pakosarjat punasena) =)
Edit: ja nyt kun muistelen niin unohdin kattoa yhen jutun, nimittäin muistin mukaan latausvalon piuha näytteli jonkunlaista tärkeähköä osaa tossa? sinne piti vetää karva jostain, ja se piti haarottaa johonkin, ja siinä piti olla diodi välissä. Voi olla, tuo liittyi automaattilaatikon juttuihin. Ettei ois ollut niin että tuo piti kytkeä jotta ylivaihde toimi A4LD:ssä, se kun oli sähkösesti ohjattu. Tarkistan huomenna..
Lähetetty: 03 Heinä 2012, 00:09
Kirjoittaja Samu
mä en ainakaan oo koskenu yhtään latausvalon piuhaan 2.8 efin kanssa että ei varmaan liity ruisku hommiin
Lähetetty: 03 Heinä 2012, 09:22
Kirjoittaja Luhtis
Jep, se meni niin että toi EEC-IV boksi ohjaa sitä A4LD:n ylivaihteen kytkeytymistä, ja jos laturi ei lataa, ei ylivaihde mene päälle. Laatikossa on ihan perinteinen solenoidi tätä tehtävää hoitamassa ja monet onkin ton toteuttanut ihan on-off kytkimellä, tolla alkuperäiskytkennällä lienee ollut tarkoitus että se OD menee päälle ja on päällä vain sillon kun Ecu hyväksyy ko. tapahtuman.
No joo, lievästi offtopic mikäli kirjoittajalla on manuaali/c3 malli.
Lähetetty: 03 Heinä 2012, 10:49
Kirjoittaja henkka
ei oo yhtää offtopic
kaikki fakta on tarpeellista, jos ei miule niin jollekki muulle
ja kiitti et sain varmistuksen tähä!
Lähetetty: 04 Heinä 2012, 10:46
Samu kirjoitti:Haynesin opas scorpioon missä selitetään v6, ohc ja dohc ja siinä on sähkökaaviot ja kaikki
Löytyy
tuolta
Lähetetty: 04 Elo 2012, 21:37
Kirjoittaja henkka
no nyt on kaikki rojut pellin alla eikä lähe tulille... ei tuu kipinää, jakaja kaikkine sytty pokseinee vaihettu toimivasta, ei auta.
suuttimet ja puola saapi sähköä ku kääntelee virtaavainta..
mikä tuossa systeemissä antaa tiedon millon pitää puolan miinus katketa (syttyhetki) ?
jos siihen löytyy vastaus ni varmasti herää suuttimetki ku näkyy kytkentäkuvan mukaan olevan kimpassa..
tässä ei vissiin ole kampiakselin asento anturia.. en ainakaa ole huomannu
yks liitin on vailla kotia siin johtosarjassa, asettuu imusarjan takapään kohalle johtosarjassa, 2 napane "abiko" ruskee/keltaruskee
toivottavasti ei oo eku paskana......
Lähetetty: 05 Elo 2012, 00:22
Kirjoittaja Samu
jos on samanlainen johtohelvetti kuin 2.8 niin imusarjan taakse ei ainakaan itellä tuu kuin virranjakajalle ja suuttimille liittimet.
ja puolan nipusta tais itellä jäädä pari johtoa turhaks kun liittyy jotenkin EGR:ään, ilmastointiin tms.
Lähetetty: 05 Elo 2012, 13:41
Kirjoittaja Luhtis
henkka kirjoitti:no nyt on kaikki rojut pellin alla eikä lähe tulille... ei tuu kipinää, jakaja kaikkine sytty pokseinee vaihettu toimivasta, ei auta.
Siinähän ei oo koneen asennon tunnistusta sinänsä muualla kun jakajassa. Eli kone merkkiin ja pyörijä sojottamaan 1. sylinteriin, kone tulille ja strobolla loput, ihan niinko ennenvanhaan. Se metallinen sakarapalikka jakajan sisällä yhdessä sen tfi-modulin kanssa pätkii maata ja haistelee kierroslukua + koneen asentoa.
Jossei tuu kipinää ollenkaan niin tuo tuskin auttaa =) tässä jotain kytkiksiä ja ohjeita ->
http://www.therangerstation.com/tech_li ... ostic.html
Lähetetty: 01 Syys 2012, 23:15
Kirjoittaja henkka
jooh.. kannattaa tarkistaa että sille poksille jatkuva virta tulee virtalukota semmosesta asennosta jossa on myös vira startti asennos.....
ja bilteman b-pumppuja en suosittele.. ja monta muuta pikku juttuu.. mut näillä se jo käy.. tyhjäkäynti vähä hakuses, ja helvetin paljon tarkempi sytystä kuin vanha kärellinen joka lähti vaik käänti 180 astetta...
mut nyt on tyhjäkäynti hakuses (ajotus) (anna vaa käydä et ruisku oppii ja putsaa tyhjäkäyntimoottori)
mis oli se vertailu taulukko mis näkee 1.6-2.3 erot? toivottavasti kelpaa katsurille:
http://www.ajovalo.net/Ford_moottorit2.htm ja koodi arc...
